Help with rules and timer.
WhiWhi
#1 Post by WhiWhi » 26 Aug 2021, 13:11
I would like help with how to solve a rule in EspEasy.
My thought is that if the temperature is above 24 degrees, it should send an email and then an email should be sent once an hour until the temperature is below 24 degrees.
How should I solve this?
My thought was like this but it does not work.
on BME280#Temperature do
   if [BME280#Temperature] > 24 and !Rules#Timer=1
     Notify,1
     timerSet,1,3600
Re: Help with rules and timer.
#2 Post by TD-er » 26 Aug 2021, 13:18
I think you also need to set a flag, like in a variable.
See the 'let' command.
Then on the temperature event you check this flag if it is above your threshold and if it isn't set, set it and also start a timer like you do now. (just start the initial timer in 1 second)
If the flag is set, leave the timer running.
On the timer event you send a notification and restart the timer.
Since it was initially set to 1 second, you also immediately send a notification.
If the temp is lower than your threshold, clear the flag and clear the timer.
Micha_he
#3 Post by Micha_he » 26 Aug 2021, 13:41
This could work (untestet):
    if %v1% = 0 AND %v2% = 0
      Notify,1
      Let,1,1  // 1h timer is running
      Let,2,1  // temp is not lower than limit
      timerSet,1,3600
  elseif %v2% = 1
    Let,2,0
on Rules#Timer=1
  Let,1,0
Edit: 'elseif' added
I read the first post again... And if you resend it after one hour, this version could work:
    if %v1% = 0 // not paused
      Notify,1
      Let,1,1
      timerSet,1,3600
    Let,1,0
    timerSet,1,0
on Rules#Timer=1
  Let,1,0
#4 Post by TD-er » 26 Aug 2021, 14:08
I think it can be simpler
      Let,1,1
      timerSet,1,1
    Let,1,0
    timerSet,1,0
on Rules#Timer=1
  timerSet,1,3600
  notify,1
WhiWhi
#5 Post by WhiWhi » 26 Aug 2021, 18:24
I will test your suggestions. I managed to solve it myself after your first post. But it is not as nice as your solutions but works.
    if [BME280#Temperature] > 24 and %v1%=0
        let,1,1
        timerSet,1,3600
        timerSet,2,1
On Rules#Timer=2 do
    Notify,1
    timerSet,2,0
On Rules#Timer=1 do
   if [BME280#Temperature] > 24 and %v1%=1
       Notify,1
       timerSet,1,3600
       let,1,0
       timerSet,1,0
#6 Post by TD-er » 26 Aug 2021, 20:51
Well the most important thing to realize is that you managed to do it yourself, and thus now know how it works :)
Users browsing this forum: No registered users and 92 guests
