Thinkspeak does not receive all of the data
Dondolo
#1 Post by Dondolo » 07 Aug 2021, 17:07
I have problems with Thinkspeak, the data is only partially arriving
Just updated to mega 20210802
ESP_Easy_mega_20210802_test_B_ESP32_4M316k.bin
I configured the Thinkspeak Controller as follows:
Task 1, 4, 60 controller no.3 should be transferred
However, only data from controller no. 1 and 4 are displayed.
Also with the command under Rules:
SendToHTTP, api.thingspeak.com, 80, / update? Api_key = xxxxxxxxxxxxx = [BH1750 # Lux]
it didn't work.
Does anyone have an idea why this might be?
Greetings Dondolo
Re: Thinkspeak does not receive all of the data
#2 Post by Ath » 07 Aug 2021, 17:19
What Controllers are configured at slots 1 and 2?
Dondolo
#3 Post by Dondolo » 07 Aug 2021, 17:57
I'm not quite sure is that what you mean?
Is this command correctly written?
SendToHTTP,api.thingspeak.com,80,/update?api_key=xxxxxxxxx&field3=[BH1750#Lux]
#4 Post by Ath » 07 Aug 2021, 19:05
You might want to take that key out of your post.
I don't speak ThingSpeak, so can't say how correct that is.
Dondolo
#5 Post by Dondolo » 07 Aug 2021, 20:14
With, typed too fast. Yes, but how?
#6 Post by Ath » 07 Aug 2021, 20:28
Your post has a pencil button in the right top, that's the Edit button ;)
Dondolo
#7 Post by Dondolo » 07 Aug 2021, 20:33
a little smarter again, thank you.
Dondolo
#8 Post by Dondolo » 07 Aug 2021, 20:35
And an idea about the actual problem?
#9 Post by TD-er » 08 Aug 2021, 00:17
What interval is used to send data to the controller?
So the interval of the tasks.
You have the controller set to only send a message every 15 sec and the queue full action is set to "ignore new".
I think with the large interval needed by Thinkspeak, you may want to set it to "delete oldest".
Also try to make a list of values you try to send and at what interval.
It could be you're filling up the queue with messages from only 1 or 2 tasks and ignoring the rest because the queue is full.
