MQTT (JASON) Rule Engine failure ?
Posted: 30 Jul 2021, 20:03
Hello experts,
I try to get my measurement to NodeRed transferred via MQTT and JASON.
After some research I could get a hint here in the Forum So I created a rule that formats the “output” as Jason and sent it via MQTT to the Broker.
Basically, it works as long I use a Single Value.
My Target is to Transfer Temperature and Humidity in one JASON.
The Problem is following line:
The Problem in the "," between the 2 Values. ("[Oben#Temperature]","Humidity")
In MQTT Explorer i can observe that the 2nd part is missing(Humidity). pls have a look on the attached picture.
Rule:
Log:
Update:
After implementing here the Log, I realized an hint in the Log:
https://github.com/letscontrolit/ESPEasy/issues/2724
Played a little bit around with different possibilities and I got it fixed by myself.
Put the whole publish command under “ ’ ”
Publish %sysname%/Sensor_%unit%/Oben,{"Temperture":"[Oben#Temperature]","Humidity":"[Oben#Humidity]"}
Rule:
on System#Boot do
timerSet,1,1
On Rules#Timer=1 do
Publish %sysname%/Sensor_%unit%/ObenT,{"ObenT":"[Oben#Temperature]"}
Publish %sysname%/Sensor_%unit%/ObenH,{"ObenH":"[Oben#Humidity]"}
timerSet,1,1
EVENT: Rules#Timer=1,1
846382: ACT : Publish xxx/Sensor_4/Oben,{'Temperture':'26.50','Humidity':'52.60'}
846388: Too many arguments: cmd=Publish Arg1=xxx/Sensor_4/Oben Arg2={'Temperture':'26.50' ExtraArg3='Humidity':'52.60'} lin
846388: Line: _Publish xxx/Sensor_4/Oben,{'Temperture':'26.50','Humidity':'52.60'}_
846388: Command not executed! See: https://github.com/letscontrolit/ESPEasy/issues/2724
846405: Command unknown: Publish xxx/Sensor_4/Oben,{'Temperture':'26.50','Humidity':'52.60'}
846417: ACT : Publish xxx/Sensor_4/ObenT,{'ObenT':'26.50'}
846441: ACT : Publish xxx/Sensor_4/ObenH,{'ObenH':'52.60'}
846453: ACT : timerSet,1,1
Update:
