p2p Config (Read another units GPIO)
My Setup (both units ok) - Unit 1 'Send' Unit 2 'Receive' Problem nothing being received ? Please advise on my setup error / understanding.
Re: p2p Config (Read another units GPIO)
What build do you use?
Looks like a relative old build.
Please also check the points mentioned here: https://espeasy.readthedocs.io/en/lates ... #c013-page
And the values on the 'device' page will perhaps not update automatically if that's the only task.
Just as test you can add another task on the 'receiving' node outputting a system info task and most important, set the "interval" of that task to 1 sec to get regular updates on the devices page.
Thanks. mega-20200426. I will try & revert.
Maybe you can try one of these builds: (later build than the 2021-05-31 on GitHub)
https://td-er.nl/ESPEasy/
The files themselves: https://td-er.nl/ESPEasy/static/
Thanks (both). Their are other tasks & they update as expected. Added the sys info which also updates. Confirm the update to 1 sec no difference. I don't really wish to update the firmware & risk another bug, unless it is known this rev does not work. Read the docs again. I guess I just want it confirmed that with what I have done already their is no obvious mistakes ?
Has the unit number of either ESP been changed since you added the 'receiving' task?
Maybe also try to share the sysinfo task (or just another one which has actually an update interval), to check if that one does work as expected
OK, just a hunch... Can you change the task variable name to a non-default string?
e.g. "testload" and add it again to the receiving node
And no update on the receiving end?
Not even if you refresh the devices tab on the receiving end?
No. Tried refreshing & rebooting. Is their any obvious error in what I did, now or in the gpio test ?
I'm not sure if it will work as expected for tasks that do not report on a regular interval like the switch plugin.
But it should work on other tasks.
The sysinfo is also a bit tricky since it does allow for dynamically select a different number of output values.
So perhaps you do have another sensor connected to the ESP, which does always send the same set of value types. (e.g. BME280)
Can you send commands to the other unit via rules using the sendto command?
See: https://espeasy.readthedocs.io/en/lates ... nd-publish
I think the simplest test is to send a logentry command to the other unit from the command field on the Tools page.
It may become a bit tricky using the various quotes, so better first try it simple like this example
sendto,2,"logentry,Test"
sendto,2,"logentry,Test" >> Success!! Appears in 'receive' unit log.
Let me try the send to command (later today) & revert. Thank you so much!
OK, this can also be used from the rules to send data to the 'other side'.
For example you can act on events from the tasks and just 'forward' them to the other node, or use commands like "taskvalueset" to set values in a dummy task.
Still I don't know why the p2p isn't working for you, but at least this may be a work-around which is a bit more flexible.
In Rules - sendTo 2,'let,1,1'
worked better than what I originally was trying to do, so thank you very much.
You're welcome
Maybe it is even better to send events to the other host.
You can include upto 4 event values, which can be accessed via %eventvalue1% ... %eventvalue4$ when handling the event.
The syntax is something like this:
Since a comma is needed in the event, I wrapped it in quotes.
Assigning a value to a variable does not trigger any event, so you cannot act on it, only use the new value.
So if you need an immediate action, you may want to consider sending an event.
sendto,2,event,"myevent#bla=12,34,56,78.90"
Users browsing this forum: No registered users and 83 guests
