How to set the countdown taskvalue
a_k
#1 Post by a_k » 17 Sep 2019, 18:29
How to set the countdown taskvalue? I would like one dummy value to change after 1 hour after reaching a given temperature. Unfortunately, the delay doesn't work and delays ALL the task. How to make it work properly? I have no idea.
on dummy#1 do
 if [10P#temperature]>78
 Delay 3000000
 TaskValueSet,11,3,1
edit:
I have an idea. But it doesn't really work the way I want it to. And if the value exceeds 3600, set the change valuetask..
on dummy#1 do
 TaskValueSet,11,3,[dummy#1]+1
Re: How to set the countdown taskvalue
#2 Post by TD-er » 17 Sep 2019, 21:36
Just use a timer ?
a_k
#3 Post by a_k » 17 Sep 2019, 21:48
Device: Output - Clock or rules? I have no idea how to do that. I try different things and nothing works... I do something wrong.
budman1758
#4 Post by budman1758 » 18 Sep 2019, 01:16
On Clock#Time=all,**:00 do
If [something#something]= something
do something
do something else
This will perform the function every hour on the hour.
https://espeasy.readthedocs.io/en/lates ... g-examples
See the "Time" section on the above page.
a_k
#5 Post by a_k » 18 Sep 2019, 04:40
It's not what he wants to do. Unfortunately, it doesn't work:
On 10P#temperatura>26 do
timerSet,1,5
On Rules#Timer=1 do
TaskValueSet,11,3,1
#6 Post by TD-er » 18 Sep 2019, 09:48
a_k wrote: 18 Sep 2019, 04:40 It's not what he wants to do. Unfortunately, it doesn't work:
timerSet,1,5
On Rules#Timer=1 do
TaskValueSet,11,3,1
That's indeed what I meant.
This doesn't work?
The timer should then be set for an hour (3600), but I can imagine it will be a bit tedious to test with an hour interval.
a_k
#7 Post by a_k » 18 Sep 2019, 09:55
I set a small interval ( 10 s ) for the tests. Unfortunately, once it works and once it does not and with different intervals... :? It doesn't work more often...
#8 Post by TD-er » 18 Sep 2019, 14:52
What do you expect the function should do?
What it does here, is that it does set the timer every time the measured value is above some threshold.
What you probably should do is add some check to see if the timer has already been set.
Also what do you think will happen when the temperature fluctuates? (which is normal when controlling a cooling installation based on temperature for example :) )
If the temp does cross the value, then you should set some flag that you've seen it crossing the threshold and set your timer.
Maybe the plugin called "level" can help you out here.
I've not used that one myself, but I've seen its code a few times.
Does look like it could help je monitor some set level + applying some hysteresis.
a_k
#9 Post by a_k » 18 Sep 2019, 15:58
TD-er wrote: 18 Sep 2019, 14:52 What it does here, is that it does set the timer every time the measured value is above some threshold.
Aah. Now I understand how it works. Thank you! I think I have an idea how to do it now. If I still don't know how. I will ask.
Now it's working properly: :) ;)
on 10P#temperatura>29 do
TaskValueSet,9,1,1
On test#test=0 do   // this task 9,1,1
timerSet,1,600
on Rules#Timer=1 do
TaskValueSet,9,2,1
Users browsing this forum: Ahrefs [Bot] and 140 guests
