Omitting errors from DS18B20 sensors
dannybloe
#1 Post by dannybloe » 18 Dec 2015, 14:36
Hiya folks,
Last night I put my first EspEasy board to the test holding two DS18B20 sensors in series measuring water flow temperature in my heating system at home. So far so good. I think though that I didn't connect the sensors 'clean' enough because sometimes it registers the notorious 85C readings indicating there's some kind of error:
The 85 degree reading is the power-up state of the DS18B20 & DS1822 sensors see datasheet page 7 http://datasheets.maximintegrated.com/en/ds/DS18B20.pdf. This means that the temperature sensor has either not received an instruction to do a temperature conversion, or it has not had the time or the power to do a conversion.
Would it somehow be possible to detect this and not send this value to the remote system (Domoticz in my case)?
Cheers,
Danny
