After adding the Emoncms Plugin R35 i thought a few notes might Help Setup:-
Click on config.
1.Change the protocol to emoncms
2.Change the controller IP to 80.243.190.58
3.Change the controller port to 80
4.Change the controller password to your emoncms write apikey
5.Change the unit number if desired - Will be passed to Emoncms as Node number
6.Keep the Sensor Delay above 15 Seconds
Note:- I have made a pull request for step 5 to work - Hopefully this will be committed to the master branch shortly
Hope these few scribbles help!!!!
Emoncms Setup Instructions - Scribbles
