I am running some 20'ish devices with ESPEasy on board.
Now, I came across this page saying
Well... Out of the box (using ESP_Easy_mega_20211005_normal_ESP8266_4M1M), none of my devices gets even close to this amount of free memory."Free Mem is available memory, this should be above 20 000 (byte) for the ESP to feel happy."
Now, I'm wondering: If I re-compile the firmware only with those plugins required for my use case - would that raise the amount of free memory?
And - if yes - could I just kick out each and every plugin? Or are there essential plugins which are required in any case?
What is the recommended way to minimize the number of installed plugins?
Thank you for your help!
Kind regards,
Kornelius
