Timer not correct
pascalbianca
Timer not correct
#1 Post by pascalbianca » 11 Apr 2020, 17:54
Hello everyone,
I have this in my rules1.txt
On System#Boot do
 gpio,12,0    //esp test test 1=aan 0 = uit
 mcpgpio, 6,0 //MCP23017 test 1=aan 0 = uit
 let,1,0
 let,2,0
 timerSet,1,5 //Set Timer 1 for the next event in 5 seconds
 timerSet,2,1 //Set Timer 2 for the next event in 2 seconds
On Rules#Timer=1 do
 if [VAR#1]=1
   let,1,0
   gpio,12,0
   let,1,1
   gpio,12,1
On Rules#Timer=2 do
 if [VAR#1]=1
   let,2,0
  mcpgpio, 6,0
   let,2,1
   mcpgpio, 6,1
But for some reason , i think my mistake , the timers are not working correct.
The first goes on and then after 5 seconds of, then led 2 on MCP23017 for 2 seconds and the loop.
But the timer of MCP23017 should normal blink faster then the timer 1.
is that normal or do i have i fould in my code?
Re: Timer not correct
#2 Post by ThomasB » 11 Apr 2020, 21:29
In the Rules#Timer 2 event you are setting var #2, but testing var #1.
I think you want this:
On Rules#Timer=2 do
 if [VAR#2]=1
   let,2,0
  mcpgpio, 6,0
   let,2,1
   mcpgpio, 6,1
pascalbianca
#3 Post by pascalbianca » 11 Apr 2020, 21:50
Thanks that's it. : :D
pascalbianca
#4 Post by pascalbianca » 13 Apr 2020, 15:20
Small question so i can understand it correct.
Let means.:
internal class
Set the value of n (1..16).
Let,<n>,<value>
But is Let a part of the timer or what is it exactly?
I tryed it in the timer to leave it away, but then the timer dos'nt do anything.
#5 Post by TD-er » 13 Apr 2020, 16:29
See the documentation: https://espeasy.readthedocs.io/en/lates ... task-names
With the command "let" you can set an internal variable to a certain value.
What the current values of your system are, can be seen on the system variables page of the web interface. (tools => System variables)
These values can be set and read using rules, but the variables can also be used in any place where you can refer to system variables (e.g. in publish topics of controllers, and many many other places)
One difference between these variables and a dummy task is that you loose their content after a reboot.
