Long press button delay
christopharris
#1 Post by christopharris » 22 Nov 2021, 06:56
Hello! I'm new to using EspEasy. I've been trying to figure it out for a few days, but I can not do anything. My task is simple. There is 1 switch. With this switch I want to operate 2 relays. By means of short and long pressing of the button. Switch is a simple press button. I can do it with the help of this rule:
on sw1#value1 do
if [sw1#value1] = 0
timerSet, 1, 1
on rules#timer=1 do
if [sw1#value1] = 1
But there is a problem - too long delay with a short press. A whole second. And it's very inconvenient. I have read that for timerSet you can not use a value of less than 1 second. I read about the delay function. I'm trying to use it instead of timerSet, but nothing happens. Maybe someone can help me?
Re: Long press button delay
#2 Post by Ath » 22 Nov 2021, 07:40
There is a mishap in your code, the endif is missing after timerSet,1,1
Documentation on rules is here: https://espeasy.readthedocs.io/en/lates ... Rules.html
on sw1#value1 do
  if [sw1#value1] = 0
    timerSet, 1, 1
on rules#timer=1 do
  if [sw1#value1] = 1
And besides the timerSet command there is also a timerSet_ms that has a milliseconds argument instead of a seconds argument, giving finer control.
The complete list of commands is here: https://espeasy.readthedocs.io/en/lates ... mmand.html
You could also react to the event value 10 or 11 when the longpress is activated, as documented in the comboboxes on the Switch settings.
Users browsing this forum: No registered users and 33 guests
