Task limit to 12 ?
Task limit to 12 ?
hello, I can't find a post regarding the task limit to 12 ... Is it possible to increase this limit ... 16 would be ideal in my case. Thank you
Re: Task limit to 12 ?
ESP8266 units support a maximum of 12 tasks, though there is a configuration possible that has 24. That wouldn't be (backward) compatible with the 12 tasks setup, as that changes the configuration files.
ESP32 units are 'limited' to 32 tasks, so that could be a fine alternative, prices for ESP32 modules are barely higher than for ESP8266, the CPU is much faster, has more RAM, and 4 or 16MB flash, and also comes with more, and more flexible, GPIO pins.
Yep, the limit for number of tasks is set at compile time and is affecting the structure of the settings file also.
In other words, changing to 24 tasks will render the existing settings incompatible.
In order to use 24 tasks on an ESP8266, you must define the following 2 defines:
-DUSE_NON_STANDARD_24_TASKS
-DTASKS_MAX=24
the -D prefix is when you set it in PlatformIO.
Or you set it in your Custom.h
-DTASKS_MAX=24
#define USE_NON_STANDARD_24_TASKS
#define TASKS_MAX 24
Sorry but i dont understand how to do this ?
What don't you understand? Where to use these C++ defines, or just how to build a custom version of ESPEasy?
if I understand correctly, I have to use software in C to open the bin and add or modify lines of programs? Then redo a custom .bin?
Well it is a bit more than that.
Maybe we can later discuss how bad you need it as we can of course make a test build for you but that would mean a lot of work to keep you updated.
So please tell why you need it now, maybe we can already help you to work around this limitation right now.
Hello to solve this little problem, I switched to esp32 wroom32 which with a suitable .bin, I am in 32 task.
BUD ...!!!
I have a problem with my esp in mqtt mode. My esp is coupled with a mcp23017 to increase the IN and OUT. When I use a mcp ... I2c input quickly (two pulses second for example) and the output concerned starts to flash constantly (see photo) ... I do not understand why. I have other ESPWemos that don't have this problem. Thank you
INFO :
I use ESP32 Wroom32
Version .bin : ESP_Easy_mega_20211105_test_A_ESP32-wrover-kit_4M316k (Impossible to flash directly with ESPEasy .. I use tasmota first and then upgrade firmware ...
When i disable "Home Assistant (openHAB) MQTT" in "controllers protocol" ... the anomaly disappears which confirms the mqtt problem since the esp only works with the rules.
normal log without mqtt of in normal use
abnormal issue
Maybe my rulse are broken ...
Thanks a lot
BUD ...!!!
INFO :
I use ESP32 Wroom32
abnormal issue
On BP1#BP1State=0 do
MCPGPIOTOGGLE,1
On BP2#BP2State=0 do
MCPGPIOTOGGLE,2
On BP3#BP3State=0 do
MCPGPIOTOGGLE,3
On BP4#BP4State=0 do
MCPGPIOTOGGLE,4
On BP5#BP5State=0 do
MCPGPIOTOGGLE,5
On BP6#BP6State=0 do
MCPGPIOTOGGLE,6
On BP7#BP7State=0 do
MCPGPIOTOGGLE,7
On BP8#BP8State=0 do
MCPGPIOTOGGLE,8
On BP9#BP9State=0 do
MCPGPIOTOGGLE,9
On BP10#BP10State=0 do
MCPGPIOTOGGLE,10
On BP11#BP11State=0 do
MCPGPIOTOGGLE,11
On BP12#BP12State=0 do
MCPGPIOTOGGLE,12
On BP13#BP13State=0 do
MCPGPIOTOGGLE,13
On BP14#BP14State=0 do
MCPGPIOTOGGLE,14
On BP15#BP15State=0 do
MCPGPIOTOGGLE,15
On BP16#BP16State=0 do
MCPGPIOTOGGLE,16
on System#Boot do
monitor,mcp,17 // Monitor MCP23017 INPUT pins.
monitor,mcp,18
monitor,mcp,19
monitor,mcp,20
monitor,mcp,21
monitor,mcp,22
monitor,mcp,23
monitor,mcp,24
monitor,mcp,25
monitor,mcp,26
monitor,mcp,27
monitor,mcp,28
monitor,mcp,29
monitor,mcp,30
monitor,mcp,31
monitor,mcp,32
monitor,mcp,1
monitor,mcp,2
on mcp#1 do
Publish,%sysname%/MCPGPIO/1,[plugin#mcpgpio#pinstate#1]
on mcp#2 do
Publish,%sysname%/MCPGPIO/2,[plugin#mcpgpio#pinstate#2]
on mcp#3 do
Publish,%sysname%/MCPGPIO/3,[plugin#mcpgpio#pinstate#3]
on mcp#4 do
Publish,%sysname%/MCPGPIO/4,[plugin#mcpgpio#pinstate#4]
on mcp#5 do
Publish,%sysname%/MCPGPIO/5,[plugin#mcpgpio#pinstate#5]
on mcp#6 do
Publish,%sysname%/MCPGPIO/6,[plugin#mcpgpio#pinstate#6]
on mcp#7 do
Publish,%sysname%/MCPGPIO/7,[plugin#mcpgpio#pinstate#7]
on mcp#8 do
Publish,%sysname%/MCPGPIO/8,[plugin#mcpgpio#pinstate#8]
on mcp#9 do
Publish,%sysname%/MCPGPIO/9,[plugin#mcpgpio#pinstate#9]
on mcp#10 do
Publish,%sysname%/MCPGPIO/10,[plugin#mcpgpio#pinstate#10]
on mcp#11 do
Publish,%sysname%/MCPGPIO/11,[plugin#mcpgpio#pinstate#11]
on mcp#12 do
Publish,%sysname%/MCPGPIO/12,[plugin#mcpgpio#pinstate#12]
on mcp#13 do
Publish,%sysname%/MCPGPIO/13,[plugin#mcpgpio#pinstate#13]
on mcp#14 do
Publish,%sysname%/MCPGPIO/14,[plugin#mcpgpio#pinstate#14]
on mcp#15 do
Publish,%sysname%/MCPGPIO/15,[plugin#mcpgpio#pinstate#15]
on mcp#16 do
Publish,%sysname%/MCPGPIO/16,[plugin#mcpgpio#pinstate#16]
- Snag_abf41f5.png (73.76 KiB) Viewed 6574 times
- Snag_abf3227.png (73.84 KiB) Viewed 6574 times
Reason: Changed quote to code tags
Just take this part of your rules:
I think this is causing the flashing.
Events are being queued, and take some time to process.
Do you also have a switch task assigned to these pins?
What is the configuration of one of such tasks (e.g. the one that is now toggling)
And what kind of controller do you use? Is there some domotica software interacting with this pin too?
MCPGPIOTOGGLE,1
my home automation works with jeedom.
I tested by deactivating jeedom and by deactivating the mqtt protocol of jeedom ... Always the same thing. The question is why with domoticz I do not have this problem?
When using Domoticz as described in the documentation, thus using the Domoticz helper, this "Domoticz Helper" does prevent the "flip-flop" behavior you're seeing.
I think the processing of the state is a bit delayed, so calling the toggle will probably call it twice as there are 2 events in the queue.
For example:
- BP1#BP1State=0
- BP1#BP1State=1
So by the time the event is processed, the state is no longer reflecting the event value.
Maybe you should not call the "toggle" but rather explicitly set the state.
For example:
- BP1#BP1State=0
- BP1#BP1State=1
I must try to understand what its options are used for in the mqtt ... maybe the solution is there or then modify the communication from BPState to Jeedom which is useless. If I managed to get jeedom to not receive this info, then it won't do anything.
I have to use the "toggle" function because when you press a button at home, it must turn on and then a second pulse to turn off the light point.Maybe you should not call the "toggle" but rather explicitly set the state.
- Snag_c2bc7c5.png (50.72 KiB) Viewed 6542 times
What does Jeedom do when it receives an update?
If Jeedom does do the switching, then maybe you should not do anything in the rules.
Also what tasks do you have?
It seems like you have something called BP1 and an MCP GPIO extender. But are they the same?
Or is "BP1" a switch input connected to another extender than what you're trying to switch?
You do post a lot of rules stuff and logs, but I don't know what is connected to what.
Maybe you should not try to do all at once, but just start with 1.
Just as I mentioned here: viewtopic.php?p=55743#p55743
Users browsing this forum: Ahrefs [Bot] and 30 guests
