Problem after reinstalling VS-Code+Platformio on Linux
Due to the disk failure, I had to reinstall VSCode and Platformio on my Linux based PC.
Supposedly I did everything according to Platformio and Letscontrol wiki`s.
But as you can see in the attached screenshot, the options related to LetsControl don't show up in the bottom toolbar.
Maybe someone will tell me what I'm doing wrong?
Re: Problem after reinstalling VS-Code+Platformio on Linux
I can't see the PlatformIO icon/plugin in the left toolbar? PlatformIO needs to be installed within VSCode, not separately, AFAICS.
And you really should read documentation on ReadTheDocs, as the Wiki is no longer maintained. https://espeasy.readthedocs.io/en/lates ... ormIO.html
You probably haven't got PlatformIO installed.
See: https://www.youtube.com/watch?v=ArqwMcYSMsU&t=2s
Also do'n use the Wiki, but ReadTheDocs: https://espeasy.readthedocs.io/en/lates ... th-vs-code
I installed PlatformIO as a plugin. But for really, The icon of Platfotmaiao is not present
What Python version is available ?
Best to check it in the console in PlatformIO
And if you can check Python there, maybe also a good idea to run
The requirements.txt file is present in the ESPEasy folder.
pip3 install -r requirements.txt
And the case was explained. As usual, a stupid error. Catalog ~ /.platformio I have physically on another disk but there is a symbolic link to ~ /.platformio. And the group was not this.
Sometimes a man has an eclipse of the mind ....
I think the more scientific name for this phenomenon is: "Blupp"
Users browsing this forum: No registered users and 42 guests
