is it possible to set the time manually
i need to test something on the esp and like to set the time manually to a certain time (23:59)
is this possible?
is this possible?
Re: is it possible to set the time manually
Directly I do not know.
What you could do is to use a local NTP server, declare it in advanced configuration on the ESP Easy device and change the NTP server time.
Sébastien - espRFLinkMQTT gateway RFLink MQTT on esp
Easier: use the Timezone Offset option in advanced configuration
Can you open an issue for it as feature request on Github?
I did look into the code, as I was convinced I had looked into it not so long ago.
See: https://espeasy.readthedocs.io/en/lates ... nds-listed
The command DateTime
Based on the documentation examples, it seems like it is already present for over a month
thanks.
i found a lot of threads but none stated that it was implemented
classic RTFM HaHa.
classic RTFM HaHa.
Datetime,2021-07-06,10:00:00
This worked for me and saved me some work. Thanks!
Brian H.
Brian H.
Users browsing this forum: No registered users and 102 guests
