Reconfig Release code with Arduino - instructions?
Hi, I want to add C014 (homie) controller - using Arduino. The readme.md file in the releases points to links - this is the only one explaining how to do it - https://www.letscontrolit.com/wiki/inde ... evelopment but it seams its old - still refers to using platform.io - or am I wrong? It refers to renaming the source folder, their is not one, only src. How do I do it?
Re: Reconfig Release code with Arduino - instructions?
It is still by far the easiest way to build a version using PlatformIO.
For example in VS code (the editor) you can add the extension platformIO and then open the main repository directory using PlatformIO menu (the "home" page of PlatformIO is shown as soon as it is installed)
But I think we really should make a tutorial for this, since lots and lots of people keep asking how to start developing and coding, so it is apparently still a big hurdle to take at first.
If you got it working to build, you need to move the define of the controller to the right set of defines in the file define_plugin_sets.h
It should also be present in the "test" builds.
Thank you for the reply.
- yes please - when you get time.I think we really should make a tutorial for this, since lots and lots of people keep asking how to start developing and coding
- I use Atom, hope it will work there as well.vs code ?
- budman1758
+1I think we really should make a tutorial for this, since lots and lots of people keep asking how to start developing and coding
Users browsing this forum: No registered users and 90 guests
