Rules problem...
Rules problem...
#1 Post by Shardan » 15 Mar 2019, 01:44
Hi all,
testing with some rules, tested with Mega version mega-20190311
With running into problems i tried an old MegaV2, same result.
on System#Boot do
   gpio,2,0
   timerset,1,10    //Set Timer 1
enddo
on rules#timer=1 do    //if Timer1 expires
   taskvalueset 5,1,1   //set dummy#var1 to 1
   timerset,2,10   //Set Timer2
enddo
on rules#timer=2 do   //If Timer2 expires
   taskvalueset 5,1,0   //set dummy#var1 to 0
   timerset,1,10   //Set Timer1
enddo
on dummy#var1 do    //If dummy#var1 changes
   gpio,2,[dummy#var1]  //Set GPIO2 to dummy#var1
enddo
It seems that only the "om System#Boot do" is executed.
The dummy#var1 is set to the last taskvalueset command, GPIO2 is set to that value.
Swapping taskvalueset 5,1,1 and taskvalueset 5,1,0 shows it always remains on the last taskvalueset value.
The timer1/Timer2 sequence should toggle it but does not. I don't see any timer events in the log.
Second problem
The GPIO2 is set to that value only once.
If i manually send a taskvalueset, the "on dummy#var1 do" is not recognized.
By the log the event from dummy#var 1 is generated.
It seems to me that even the "On dummy#var1" is not executed.
What is going wrong? Maybe I'm partially blind again ;)
Re: Rules problem...
#2 Post by Shardan » 15 Mar 2019, 02:04
Hello again,
Some more info
The timer-part seems to be a problem with setting the timer value.
With rebooting and external (serial) logger i see the following:
EVENT: System#Boot
ACT  : timerSet,1,10
ACT  : enddo
ACT  : on Rules#Timer=1 do
ACT  : taskvalueset 5,1,0
ACT  : timerSet,2,10
ACT  : enddo
ACT  : on Rules#Timer=2 do
ACT  : taskvalueset 5,1,1
ACT  : timerSet,1,10
ACT  : enddo
These steps are not executed after 10 seconds but at once.
Seems the "timerSet,1,10" is not correct.
The event on changing "dummy#var1" is generated if I change the value manually:
EVENT: dummy#var1=0.00
but the "gpio,2,[dummy#var1] is not executed.
#3 Post by ThomasB » 15 Mar 2019, 03:55
enddo is incorrect syntax. Correct usage is endon.
Revised rules with syntax corrections:
on System#Boot do
   gpio,2,0
#4 Post by Shardan » 15 Mar 2019, 17:02
Grrrr... 6 weeks away and everything is forgotten..
Many thanks, i knew i was blind....
budman1758
#5 Post by budman1758 » 16 Mar 2019, 17:36
They say the first thing that goes is memory....... Can't remember what the second thing was....... :lol: :lol:
#6 Post by Shardan » 16 Mar 2019, 20:30
definitely right, from my own experience......
:D
