Hi everyone,
I'd like to setup ESPEasy in my NodeMCU with a RF TX FS1000A in order to open/close mi garage door. I've cloned the original command (with the RF receiver and a few lines of code in arduino IDE) and I discovered the bit sequence. Using the raw code in arduino/NodeMCU I can open/close the door and I'd like to accomplish the same operations with EspEasy. Is it possible?
I didn't find a solution for such problem and every post I read leads to RFLink. My target is to send a 96 bit sequence (always the same for 10 or 20 times in a brief time range) to FS1000A (using MQTT would be the best).
Can you suggest me if exists a way to accomplish this with ESPEasy?
Thx for your replies
TX RF garage sequence
Users browsing this forum: No registered users and 44 guests
