uPyEasy v0.2.3 released
LisaM
#1 Post by LisaM » 02 Apr 2018, 20:19
The firmware can be found in the uPyEasy releases section: https://github.com/letscontrolit/uPyEas ... s/tag/BETA
Added: uPyEasy AP mode when no SSID is set. This will make uPyEasy behave the same as ESPEasy when freshly flashed.
If you have already uPyEasy installed and want to try this new functionality?
- Flash new firmware (settings are kept)
- Goto config and erase SSID and WPA Key
- Goto tools and reboot
Now uPyEasy will go into AP mode and broadcast the AP 'uPyEasy'.
Connect to it using smartphone or whatever and use your browser to goto 192.168.4.1.
The rest is the same as ESPEasy...
crazysky
Re: uPyEasy v0.2.3 released
#2 Post by crazysky » 03 Feb 2020, 20:12
Hi Lisa,
I do use the latest build upyeasy_v031_20180601_test_esp32_4096.bin
on a espressif esp32-wroom-32
I can upload the bin-file and a new access point appears which provides me the website where you can set your SSID and the WPA key.
Also I can see my wifi network in the list.
The problem is, if I type in the SSID and the password, click submit, nothing happens. It seems to be that these things are not saved.
Any idea?
Greetings
Sven
