i have the newest Software on my RFLink Module ( Arduino Mega with R47 ) and a RFLink Board from Nodo Shop ( V 1.1.4 ).
433 Mhz works since a couple of Month, but if i put a NRF2401 Module on this Board an start RFLinkloader, no commands from my Milight remote Controll is shown in the Debug Window. MiLight Protocoll is set to on.....
Whats wrong? Tried also another NRF2401 Module.
RFLink 2,4Ghz MiLight does not work
Re: RFLink 2,4Ghz MiLight does not work
If you followed the manual to solder it, then you are missing the legs below the connector. You will have to solder the legs to under it as the package from nodo does not contain the legs, they have it only for the right side of the pcb. The other side has the holes but the legs have to be soldered in.
Please let me know if this solved your issue.
I'm only struggling now how to enable the milight feature on the board without rflinkloader.
Users browsing this forum: No registered users and 42 guests
