RFLink - RTS remote control removed
cocolito
#1 Post by cocolito » 13 Sep 2020, 00:39
Just after pairing all my Somfy RTS blinds with my RFLink I lost the communication between my real remote and my blinds.
The pairing button doesn't work for all my remote did someone already has this issue ? Is there a solution in order to repairing the real remote ?
Stuntteam
Site Beheer
Re: RFLink - RTS remote control removed
#2 Post by Stuntteam » 13 Sep 2020, 00:55
RFLink should not use the same ID as your original remote.
Also make sure not too add too many remote ID's to your blinds
cocolito
#3 Post by cocolito » 13 Sep 2020, 20:58
Yes it was my first mistake but now I fix this issue.
I want to re pair my remote to my blinds how can I do that ? I've seen somfy tuto but all my blinds are wired to the same power link and so I can't just disconnect a single blind how
Did a command exist on the rflink to send a sync mode to my blind ?
grillp
#4 Post by grillp » 21 Jan 2021, 07:02
Not sure if you found a solution (Your post was from Sep 2020) but,
I have Somfy Sonese 30 Blinds (which are Wireless/LiIon not wired) and they have a programming button on them (near where I plug in the charger to charge the battery).
If I press that for 3-4 seconds the blinds go into programming mode and then just need to press the programming button on the remote to pair them.
Does yours have a programming button like that?
G./
