KaKu awst-6000 en APIR-2150 (2019) not detected by RFLink
MrDomo
#1 Post by MrDomo » 08 Jun 2019, 21:22
Hi There,
Has is there anyone who can detect these sensors in RFLink, i use R48 en tested with de R33 developer version but with no suc6. The awst-6000 looks the same as the previous ones, only feels a bit more cheap plastic, but ik looks the protocol used is changed, i can pair with te original wall outlets, so they work, I also can hear the signal on a amateur radio.
Ik tryed to use the unsupported / learning option with de RFLink loader but with no success. I used debug and i can see rflink is receiving the signal but not recognised.
De sensors are from the Start Line (blue) and the supposed to be te older NewKaku. (one thing Kaku is now Trust).
I searched a lot on the Net but no information available, i also tested with arduino library NewRemoteReceiver, also not recognised.
Can you please add this sensors to RFLink, i guess i'm not the only one, assuming RF433 is still actual.
10;rfdebug=on;
20;62;RFDEBUG=ON;
20;63;DEBUG;Pulses=511;Pulses(uSec)=390,1110,300,60,300,1110,270,90,240,1140,240,120,240,1170,240,120,240,120,240,1170,240,120,240,1170,210,150,210,1170,210,1200,210,150,210,1170,210,150,210,1200,210,150,210,150,210,1200,210,1200,210,150,180,1200,210,150,210,150,210,1200,180,180,180,1200,180,1200,180,150,180,1230,180,180,180,1200,180,150,180,150,180,1230,180,150,180,1230,180,180,180,1230,180,180,180,1230,180,1230,180,150,180,1230,180,150,180,180,180,1200,180,180,180,1230,180,1230,180,180,180,1230,180,180,180,150,180,1230,180,150,180,1230,180,1230,180,180,150,5550,180,2520,210,150,210,1200,210,1200,210,150,210,1200,210,150,210,1200,210,150,210,1200,210,150,180,150,210,1200,210,150,210,1200,210,150,210,1200,210,1200,180,150,210,1200,180,150,180,1200,180,150,180,150,210,1200,180,1200,210,150,210,1200,210,150,180,150,180,1200,180,180,180,1200,180,1200,180,150,210,1200,180,150,210,1200,180,150,180,180,180,1200,180,150,180,1200,180,150,210,1200,180,150,180,1200,210,1200,180,150,180,1200,210,150,180,180,180,1200,180,180,180,1200,180,1200,180,150,210,1200,180,150,180,150,180,1200,180,180,180,1200,180,1200,180,150,180,5550,180,2520,210,150,210,1200,210,1200,210,150,210,1200,180,150,210,1200,210,150,210,1200,210,150,210,150,210,1200,180,150,210,1200,180,150,210,1200,180,1200,180,150,210,1200,180,150,180,1200,180,150,180,180,180,1200,180,1230,180,180,180,1230,180,180,180,150,180,1230,180,150,180,1200,180,1200,180,150,180,1230,180,150,180,1230,180,150,180,180,180,1200,180,180,180,1200,180,180,180,1200,180,180,180,1230,180,1230,180,180,180,1200,180,150,180,150,180,1230,180,150,180,1230,180,1230,180,150,180,1230,180,150,180,180,180,1200,180,180,180,1200,180,1230,180,180,180,5550,180,2520,210,150,210,1200,210,1200,210,150,210,1200,210,150,210,1200,180,150,210,1200,180,150,210,150,180,1200,210,150,180,1200,210,150,210,1200,180,1200,180,150,180,1200,180,150,180,1200,180,150,180,180,180,1200,180,1200,180,150,180,1230,180,150,180,180,180,1200,180,180,180,1200,180,1230,180,180,180,1200,180,180,180,1200,180,150,180,180,180,1230,180,180,180,1200,180,180,180,1200,180,180,180,1200,180,1230,180,150,180,1230,180,180,180,180,180,1230,180,180,180,1230,180,1200,180,180,180,1200,180,180,180,150,180;
20;64;DEBUG;Pulses=511;Pulses(uSec)=240,150,180,1170,150,150,180,1140,180,1140,180,150,180,1230,180,180,180,180,180,1230,180,180,180,1230,180,1230,180,150,180,1230,180,180,180,180,180,1230,180,180,180,1230,180,1230,180,180,180,5550,180,2520,210,150,210,1200,210,1200,180,150,210,1200,180,150,180,1200,180,150,180,1200,180,150,180,150,180,1200,180,180,180,1200,180,180,180,1200,180,1230,180,180,180,1230,180,150,180,1230,180,150,180,180,180,1230,180,1230,180,180,180,1230,180,180,180,180,180,1230,180,150,180,1200,180,1230,180,180,180,1230,180,180,180,1230,180,150,180,180,180,1200,180,180,180,1200,180,180,180,1230,180,180,180,1230,180,1230,180,180,180,1200,180,180,180,180,180,1230,180,150,180,1230,180,1230,180,180,180,1230,180,180,180,180,180,1200,180,180,180,1200,180,1230,180,180,180,5550,180,2520,180,150,210,1200,180,1200,210,150,210,1200,210,150,210,1200,180,150,180,1200,180,180,180,180,180,1230,180,180,180,1200,180,150,180,1200,180,1200,180,150,180,1230,180,180,180,1230,180,150,180,180,180,1200,180,1230,180,150,180,1230,180,150,180,180,180,1230,180,180,180,1230,180,1230,180,180,180,1200,180,180,180,1200,180,180,180,180,180,1230,180,180,180,1230,180,180,180,1200,180,180,180,1200,180,1230,180,180,180,1230,180,180,180,180,180,1230,180,180,180,1230,180,1200,180,180,180,1230,180,180,180,180,180,1230,180,180,180,1230,180,1230,180,180,150,5550,180,2520,210,150,210,1200,210,1200,180,150,180,1200,210,150,180,1200,210,150,180,1200,210,150,180,180,180,1200,180,180,180,1200,180,180,180,1200,180,1230,180,150,180,1200,180,180,180,1200,180,180,180,180,180,1230,180,1200,180,180,180,1230,180,180,180,180,180,1200,180,180,180,1200,180,1230,180,150,180,1230,180,180,180,1230,180,180,180,180,180,1230,180,180,180,1230,180,180,180,1230,180,180,180,1230,180,1230,180,180,180,1230,180,150,180,180,180,1200,180,180,180,1200,180,1230,180,180,180,1230,180,180,180,180,180,1230,180,180,180,1230,180,1200,180,180,180,5550,180,2520,210,150,210,1200,210,1200,180,150,210,1200,210,150,180,1200,210,150,210,1200,210,150,180,150,180,1200,180,150,180,1230,180,180,180,1200,180,1230,180,150,180,1230,180,180,180,1230,180,180,180,180,180,1230,180,1230,180,180,180,1200,180,180,180,150,180,1230,180,180,180,1230,180,1230,180;
Greetz,
Marcel.
opm: I already send a mail with the debug data to frank zirrone, so i wait for a reaction
jni
Re: KaKu awst-6000 en APIR-2150 (2019) not detected by RFLink
#2 Post by jni » 22 Dec 2019, 14:48
I’ve exactly the same issue: AWST-6000 is not detected by rflink, debug mode shows some data coming in, learning mode doesn’t work either.
Besides that I checked the release notes of the upcoming R49 release, nothing about the KaKu AWST-6000. Would be nice if support can be added soon.
I sent an e-mail to the same e-mail address as well but no response. Any news/update to share on this topic?
KR
JNI
Stuntteam
Site Beheer
#3 Post by Stuntteam » 22 Dec 2019, 23:48
we are looking into it
jni
#4 Post by jni » 27 Dec 2019, 22:39
Thanks. I was planning to return it to the store if it’s not working. Already any idea why it’s not working?
Zilverspreeuw
#5 Post by Zilverspreeuw » 16 Mar 2020, 10:27
is there already a solution?
jni
#6 Post by jni » 16 Mar 2020, 20:42
As far as I know there is no solution at this moment.
@Stuntteam, according to your last post you are looking into it but do you already have news to share?
air112
#7 Post by air112 » 13 Sep 2020, 07:22
Is there a solution or workaround for this problem ?
Regards, Alex
