Digimax RTS10
Kaleo
Digimax RTS10
#1 Post by Kaleo » 15 Jan 2021, 14:17
Dear All,
I have a Digimax RTS10 receiver to control my boiler.
Today, I use an old Zibase to send ON and OFF commands and I would like to remove this zibase and replace it with RFLink.
Unfortunatly, this RTS10 protocol is unknown by rflink (it is mentionned as RFS10 on the zibase, "Digimax RTS10 / RFS10 / TLX1206" by RFXCom). It seems to be more or less near from X10 as it almost uses a home addressing.
Mine is associated on address D1.
Image from https://www.abavala.com/rfs10-un-action ... haudieres/
Here are frames captured by RFlink R48, when On or Off are sent by Jeedom->Zibase
RTS10 D1 On
20;24;DEBUG;Pulses=92;Pulses(uSec)=1200,4080,390,1650,420,1650,390,510,420,1650,390,510,390,1680,390,1650,420,1680,420,510,420,510,420,1650,390,1680,390,510,390,510,390,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,1650,390,1680,420,510,420,510,420,510,420,510,390,510,390,1680,390,510,390,1680,390,510,420,510,420,510,420,510,420,510,390,1680,390,510,390,1680,420,510,420,1650,420,510,420,1650,390,6990;
20;25;DEBUG;Pulses=76;Pulses(uSec)=60,1590,360,480,360,480,390,1560,390,1590,390,480,390,480,390,510,390,540,390,510,390,510,390,510,390,1650,390,510,420,1650,390,1650,390,1680,390,510,390,510,390,510,390,510,420,510,420,1650,390,510,420,1680,390,510,390,510,390,510,390,510,390,510,420,1650,420,510,420,1680,390,510,390,1680,390,510,390,1650,390,6990;
20;26;DEBUG;Pulses=88;Pulses(uSec)=1200,1590,390,480,390,1560,360,480,360,1590,360,1650,420,1680,420,510,420,510,420,1650,390,1680,390,510,390,510,390,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,1650,420,1680,420,510,420,510,420,510,390,510,390,510,390,1680,390,510,390,1680,390,510,390,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,420,1650,420,510,420,1650,390,6990;
20;27;DEBUG;Pulses=78;Pulses(uSec)=450,1590,390,1590,360,480,360,480,360,1590,390,1620,390,510,420,510,420,510,420,510,390,510,390,510,390,510,390,1650,420,510,420,1650,390,1650,420,1680,390,510,390,510,390,510,390,510,420,510,420,1650,390,510,420,1680,390,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,390,510,390,1680,390,510,390,1650,390,6990;
20;28;DEBUG;Pulses=86;Pulses(uSec)=1200,480,390,1590,390,480,390,1590,360,1590,390,1680,420,510,420,510,420,1650,390,1680,390,510,390,510,390,510,390,510,420,510,420,510,420,510,420,1650,420,510,390,1680,390,1680,390,1680,420,510,420,510,420,510,420,510,420,510,390,1680,390,510,390,1680,420,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,420,1650,390,510,420,1650,420,6990;
20;29;DEBUG;Pulses=80;Pulses(uSec)=360,1590,390,1560,390,1590,360,480,390,480,360,1590,420,1650,390,510,420,510,420,510,390,540,390,510,390,510,390,510,390,1680,390,510,390,1650,420,1650,420,1680,390,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,390,510,390,510,390,510,390,510,390,510,390,1650,390,510,390,1680,420,510,390,1650,390,510,390,1680,390,6990;
20;2A;DEBUG;Pulses=86;Pulses(uSec)=1200,480,390,1590,390,450,390,1590,360,1590,390,1620,420,510,420,510,420,1650,420,1650,390,510,390,510,390,510,390,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,1680,390,1680,420,510,420,510,420,510,420,510,420,510,390,1680,390,510,390,1680,420,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,390,1650,390,510,420,1650,420,6990;
20;2B;DEBUG;Pulses=80;Pulses(uSec)=360,1590,390,1560,390,1590,360,480,390,480,360,1590,390,1650,420,510,420,510,420,510,420,540,420,510,390,510,390,510,390,1680,390,510,390,1650,420,1650,390,1680,390,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,420,510,390,510,390,510,390,510,390,510,390,1650,390,510,420,1680,420,510,420,1650,390,510,390,1680,390,6990;
I send a second "On" just after to be sure...
20;39;DEBUG;Pulses=92;Pulses(uSec)=1200,4080,390,1680,390,1650,390,510,420,1650,420,510,420,1650,390,1680,390,1680,390,510,420,510,420,1650,420,1650,390,510,390,510,390,510,390,540,390,510,390,510,420,510,420,1650,420,510,420,1650,390,1680,390,1680,420,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,390,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,390,1650,390,510,390,1650,420,6990;
20;3A;DEBUG;Pulses=76;Pulses(uSec)=60,1590,390,480,360,480,390,1560,390,1560,390,480,390,480,390,510,420,510,420,510,420,510,390,510,390,1680,390,510,390,1650,390,1650,420,1680,390,510,390,510,390,510,390,510,390,510,390,1650,390,510,420,1680,420,510,390,510,390,510,390,510,390,510,390,1680,390,510,420,1680,390,510,390,1650,390,510,390,1680,390,6990;
20;3B;DEBUG;Pulses=88;Pulses(uSec)=1200,1590,360,480,390,1560,390,480,390,1590,360,1650,390,1680,390,510,420,510,420,1650,420,1650,390,510,390,510,390,510,390,540,390,510,390,510,390,510,420,1650,420,510,420,1650,390,1680,390,1680,390,510,420,510,420,510,420,510,390,510,390,1650,390,510,390,1680,390,510,390,510,390,510,420,510,420,510,420,1650,420,510,420,1680,390,510,390,1650,390,510,420,1650,420,6990;
20;3C;DEBUG;Pulses=78;Pulses(uSec)=450,1590,390,1590,390,480,360,480,360,1590,360,1620,390,510,420,510,390,510,390,510,420,510,420,510,420,510,390,1680,390,510,390,1650,420,1650,420,1680,390,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,420,510,420,510,420,510,390,510,390,510,390,1680,390,510,390,1680,420,510,420,1650,420,510,390,1680,390,6990;
20;3D;DEBUG;Pulses=86;Pulses(uSec)=1200,480,390,1590,390,480,390,1590,390,1590,390,1680,390,510,420,510,390,1650,420,1650,420,510,390,510,390,510,390,540,390,510,390,510,390,510,420,1650,420,510,420,1650,390,1650,390,1680,390,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,390,510,390,510,420,510,420,510,420,1650,420,510,420,1680,390,510,390,1680,390,510,420,1650,390,6990;
20;3E;DEBUG;Pulses=80;Pulses(uSec)=360,1590,360,1560,390,1590,390,450,390,480,390,1590,390,1680,390,510,420,510,420,510,420,510,390,510,420,510,420,510,420,1650,390,510,390,1680,390,1650,420,1680,420,510,420,510,390,510,390,510,390,510,390,1680,390,510,420,1680,420,510,420,510,420,510,420,510,390,510,390,1680,390,510,390,1680,420,510,420,1650,420,510,420,1650,390,6990;
20;3F;DEBUG;Pulses=86;Pulses(uSec)=1200,480,360,1590,390,480,390,1590,390,1590,360,1620,390,510,390,510,420,1650,420,1650,420,510,390,510,390,510,390,540,390,510,390,510,390,510,390,1650,420,510,420,1650,420,1650,390,1680,390,510,390,510,420,510,420,510,420,510,420,1650,420,510,390,1680,390,510,390,510,390,510,390,510,420,510,420,1650,420,510,420,1680,390,510,390,1680,390,510,390,1650,420,6990;
20;40;DEBUG;Pulses=80;Pulses(uSec)=360,1590,360,1560,390,1590,390,480,390,480,390,1590,390,1680,390,510,390,510,420,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,1650,420,1680,420,510,420,510,390,510,390,510,390,510,390,1680,390,510,420,1680,420,510,420,510,420,510,420,510,390,510,390,1680,390,510,390,1680,420,510,420,1650,420,510,420,1650,390,6990;
RTS10 D1 Off
20;49;DEBUG;Pulses=92;Pulses(uSec)=1200,4080,420,1650,390,1680,390,510,390,1650,420,510,420,1650,420,1650,390,1680,390,510,390,510,390,1650,420,1650,420,510,420,510,390,510,390,540,390,510,390,510,390,1650,420,510,420,510,420,1650,420,1650,390,540,390,510,390,510,390,510,390,510,390,510,420,1650,420,510,420,1680,390,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,420,510,390,1680,390,510,390,1680,390,6990;
20;4A;DEBUG;Pulses=76;Pulses(uSec)=210,1590,390,480,390,480,390,1560,360,1590,390,480,390,480,390,510,390,510,420,510,420,510,420,1650,420,510,420,510,390,1680,390,1680,390,510,420,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,390,510,420,510,420,510,420,510,420,1650,420,510,390,1680,390,510,390,1650,420,510,420,1650,420,6990;
20;4B;DEBUG;Pulses=88;Pulses(uSec)=1200,1560,390,480,390,1560,390,480,360,1560,390,1650,420,1680,390,510,390,510,390,1650,390,1650,420,510,420,510,420,510,420,510,420,510,420,510,390,1650,390,510,390,510,390,1650,420,1650,420,510,420,510,420,510,390,510,390,510,390,510,390,1680,390,510,420,1680,420,510,420,510,420,510,420,510,390,510,390,1650,390,510,390,1680,420,510,420,1650,420,510,420,1650,390,6990;
20;4C;DEBUG;Pulses=78;Pulses(uSec)=450,1590,390,1590,360,480,390,480,390,1590,390,1620,420,510,420,510,390,510,390,540,390,510,390,510,390,1650,420,510,420,510,420,1650,420,1650,390,540,390,510,390,510,390,510,390,510,420,510,420,1650,420,510,420,1680,390,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,420,510,390,1680,390,510,390,1650,420,6990;
20;4D;DEBUG;Pulses=86;Pulses(uSec)=1200,480,390,1590,390,450,390,1590,360,1590,390,1680,420,510,420,510,420,1650,390,1680,390,510,390,510,390,510,390,510,420,510,420,510,420,1650,420,510,420,510,390,1680,390,1650,390,510,420,510,420,510,420,510,420,510,420,510,420,1650,390,510,420,1680,390,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,390,1650,420,510,420,1650,420,6990;
20;4E;DEBUG;Pulses=80;Pulses(uSec)=450,1560,390,1560,390,1590,390,480,390,480,390,1590,390,1650,420,510,420,510,420,510,420,510,420,510,420,510,390,1650,390,510,390,510,390,1650,420,1650,420,510,420,510,420,510,390,510,390,510,390,510,390,1650,420,510,420,1680,420,510,420,510,420,510,390,510,390,510,390,1650,390,510,390,1680,420,510,420,1650,420,510,390,1680,390,6990;
20;4F;DEBUG;Pulses=86;Pulses(uSec)=1200,480,360,1560,390,480,390,1590,390,1560,390,1620,390,510,390,510,420,1650,420,1650,420,510,390,510,390,510,390,540,390,510,390,510,390,1650,420,510,420,510,420,1650,420,1650,390,540,390,510,390,510,390,510,420,510,420,510,420,1650,420,510,420,1680,390,510,390,510,390,510,390,510,390,510,420,1650,420,510,420,1680,390,510,390,1650,390,510,390,1650,420,6990;
20;50;DEBUG;Pulses=80;Pulses(uSec)=450,1590,360,1560,390,1590,390,480,390,450,390,1590,390,1650,390,510,390,510,420,510,420,510,420,510,420,510,420,1650,420,510,390,510,390,1680,390,1650,420,510,420,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,390,1650,420,510,420,1650,420,6990;
Here again I send another Off command just after:
20;5A;DEBUG;Pulses=92;Pulses(uSec)=1200,4080,390,1650,420,1650,420,510,420,1650,390,510,390,1650,390,1650,420,1680,420,510,420,510,420,1650,390,1680,390,510,390,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,510,390,1680,390,1650,420,510,420,510,420,510,420,510,420,510,390,510,390,1650,390,510,390,1680,420,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,420,1650,420,510,420,1650,390,6990;
20;5B;DEBUG;Pulses=76;Pulses(uSec)=240,1590,390,480,390,480,390,1560,390,1590,390,450,390,480,420,510,420,510,390,510,390,510,390,1650,390,510,390,510,420,1650,420,1650,420,510,390,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,420,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,420,510,420,1650,390,510,390,1680,390,6990;
20;5C;DEBUG;Pulses=88;Pulses(uSec)=1200,1590,390,480,390,1560,390,480,390,1590,390,1650,390,1680,420,510,420,510,420,1650,420,1650,390,510,390,510,390,510,390,540,390,510,390,510,420,1650,420,510,420,510,420,1650,390,1650,390,540,390,510,390,510,420,510,420,510,420,510,420,1650,420,510,390,1680,390,510,390,510,390,510,420,510,420,510,420,1650,420,510,420,1680,390,510,390,1650,390,510,420,1650,420,6990;
20;5D;DEBUG;Pulses=78;Pulses(uSec)=450,1560,390,1590,390,480,390,480,390,1590,390,1650,390,510,420,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,510,390,1680,390,1650,420,510,420,510,420,510,420,510,420,510,390,510,390,1650,390,510,390,1680,420,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,420,510,420,1650,420,510,420,1650,390,6990;
20;5E;DEBUG;Pulses=86;Pulses(uSec)=1200,480,390,1560,390,450,390,1590,390,1560,390,1680,390,510,390,510,390,1650,420,1650,420,510,420,510,420,510,420,510,390,510,390,510,390,1650,390,510,420,510,420,1650,420,1650,420,540,390,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,420,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,420,510,420,1650,390,510,390,1680,390,6990;
20;5F;DEBUG;Pulses=80;Pulses(uSec)=450,1560,390,1560,360,1590,390,480,390,480,390,1590,420,1650,390,510,390,510,390,510,390,540,390,510,420,510,420,1650,420,510,420,510,420,1650,390,1650,390,540,390,510,420,510,420,510,420,510,420,510,420,1650,390,510,390,1680,390,510,390,510,390,510,420,510,420,510,420,1650,420,510,420,1680,390,510,390,1650,390,510,420,1650,420,6990;
20;60;DEBUG;Pulses=86;Pulses(uSec)=1200,480,360,1590,360,480,390,1590,360,1590,390,1620,420,510,420,510,390,1680,390,1680,390,510,420,510,420,510,420,540,420,510,420,510,420,1650,390,510,390,510,390,1650,390,1650,420,510,420,510,420,510,420,510,390,510,390,510,390,1680,390,510,390,1680,420,510,420,510,420,510,420,510,420,510,390,1650,390,510,390,1680,420,510,420,1650,420,510,420,1650,390,6990;
20;61;DEBUG;Pulses=80;Pulses(uSec)=450,1560,390,1560,390,1620,360,480,390,480,360,1590,420,1650,420,510,420,510,420,510,390,540,390,510,390,510,390,1680,390,510,420,510,420,1650,420,1650,390,540,390,510,390,510,390,510,390,510,390,510,420,1650,420,510,420,1680,390,510,390,510,390,510,390,510,390,510,390,1650,420,510,420,1680,420,510,420,1650,390,510,390,1680,390,6990;
Do some other users have this device? Do you know if it can be added to RFlink?
I can code but I did not find any informations about this protocol. Does someone have infromations about it?
Many thanks for your help.
Kaléo.
Kaleo
Re: Digimax RTS10
#2 Post by Kaleo » 31 Jan 2021, 15:20
Dear all,
As I can see, RFLink is not dead but... it is dozing (last firmware on 18/10/2017).
I can understand this as many of us are asking for new supports.
Neverstheless, it does not give a good image of RFLink and the hope to have a device supported in the futur is really uncertain, so rflink become day after day less and less a safe investment.
Moreover, I think that many of us would be OK to help this developement ( I do).
So, isn't there a way to help you? I can compile arduino code, I can scan and record things with RTL-SDR.
Could you please just say "Hello"/"We are coming soon"/ "We need/don't need help"/ or some news? (last news on the website are from 29 DECEMBER 2019)
Please, understand that my purpose is really to help RFLink as I think it is a really good project. I fill sad to see it so asleep when other project are growing fast in the home automotion world.
Best Regards,
Kaléo.
Stuntteam
Site Beheer
Re: Digimax RTS10
#3 Post by Stuntteam » 31 Jan 2021, 21:38
We are working on it..
As soon as it is ready we will contact you for some tests.
Kaleo
Re: Digimax RTS10
#4 Post by Kaleo » 01 Feb 2021, 20:59
Thank you Stuntteam, I hope you also have good news for other people.
Regards.
Kaleo
Re: Digimax RTS10
#5 Post by Kaleo » 03 Feb 2021, 02:41
Dear All,
So... with some hours and concentration, with some research also, I have been able to decode RTS10 orders coming from my old Zibase and also send orders to my RTS10 receiver.
It was not so hard with the help of rtl-sdr. The main problem was that the debug lines of RFLink are wrong! This confused me a lot at the beginning.
The debug data of Rflink gave me 8 frames of 92,74,88,76,86,78,86,78 while these frames are all the same with 92 pulses. Except the first frame, all the beginning of the others are truncated.
I sent some orders with differents home and units adresses, on and off commands to read and understand what I needed.
If you are interested in the support of this protocol, I can give you my sources.
Regards,
Kaléo.
Users browsing this forum: No registered users and 39 guests
