I have 3 radio controlled blinds left in 433 Mhz, I don't know the brand, it seems to be French. The remote control is referenced RE302 http://www.telco-motor.fr/automatismes/ ... ulant.html
Do you have any idea if these can be managed by RFLINK?
Thanks in advance.
/Jean-Luc
Here is the result of the "debug" mode:
I pressed the remote control buttons in the following order: DOWN - STOP -UP
2018-10-31 12:45:50 - 20;1D;DEBUG;Pulses=30;Pulses(uSec)=120,540,60,540,60,540,60,540,60,540,60,540,60,540,60,540,30,570,60,540,60,540,60,540,30,570,60,540,30,600;
20;1E;DEBUG;Pulses=33;Pulses(uSec)=510,750,300,330,720,750,720,330,300,720,720,720,330,330,720,330,300,330,300,330,300,330,300,330,300,720,330,330,720,330,300,750,30;
20;1F;DEBUG;Pulses=26;Pulses(uSec)=750,330,270,300,270,690,300,270,690,300,300,300,240,360,270,330,270,690,690,750,300,300,720,750,300,6990;
20;20;DEBUG;Pulses=63;Pulses(uSec)=330,300,270,300,300,270,300,300,270,300,270,300,300,270,300,300,300,300,300,330,300,330,270,300,300,300,300,330,300,330,300,330,300,300,300,300,300,300,300,330,300,330,300,300,300,3930,300,330,300,330,300,720,720,750,300,330,720,750,720,330,300,750,240;
2018-10-31 12:45:53 - 20;21;DEBUG;Pulses=61;Pulses(uSec)=120,570,60,540,60,540,60,540,60,540,60,540,60,540,60,540,90,330,300,330,300,330,300,330,300,300,300,330,270,330,300,330,300,300,300,330,300,300,300,330,300,330,300,300,300,300,300,330,300,330,300,300,300,300,300,300,300,330,300,330,90;
2018-10-31 12:45:54 - 20;22;DEBUG;Pulses=23;Pulses(uSec)=300,300,600,780,660,330,270,330,270,330,270,690,660,690,300,300,330,300,330,300,720,330,60;
20;23;DEBUG;Pulses=51;Pulses(uSec)=390,300,300,300,240,390,300,300,300,300,300,300,300,330,300,330,300,300,300,300,300,300,300,330,300,330,300,330,300,300,300,300,300,330,300,300,300,330,300,300,300,300,300,300,300,3900,300,720,720,750,150;
20;24;DEBUG;Pulses=34;Pulses(uSec)=750,330,270,330,270,330,270,690,690,690,300,270,300,270,300,270,720,330,300,750,300,300,720,720,720,330,240,390,300,330,300,750,300,6990;
20;25;DEBUG;Pulses=29;Pulses(uSec)=150,270,300,300,270,300,300,330,270,300,300,300,270,300,270,300,300,270,300,300,270,300,270,300,270,330,300,300,60;
20;26;DEBUG;Pulses=90;Pulses(uSec)=360,270,690,690,690,330,270,300,270,300,270,300,270,690,300,270,300,270,690,360,270,330,300,330,300,330,300,330,300,330,300,750,330,300,720,330,300,750,330,300,720,330,300,330,300,750,720,330,300,750,330,300,330,300,720,750,720,330,270,330,300,330,300,750,720,750,300,330,330,300,330,300,720,330,300,750,330,300,720,750,720,360,300,330,300,330,300,720,300,6990;
2018-10-31 12:45:59 - 20;27;DEBUG;Pulses=135;Pulses(uSec)=30,330,300,330,300,330,300,300,300,300,300,330,300,330,300,300,300,300,300,330,300,330,300,330,300,300,300,300,300,330,300,330,300,300,300,3900,300,720,720,330,300,750,300,300,330,300,720,750,300,330,720,330,300,750,330,330,300,300,720,330,300,330,300,330,270,330,300,720,330,300,330,300,720,330,300,360,270,330,300,330,300,330,300,750,330,300,330,330,300,300,720,330,300,750,720,750,330,330,330,330,300,300,330,300,720,330,300,720,330,300,330,300,720,750,330,300,720,720,330,300,720,750,300,330,720,750,720,330,300,720,330,300,330,300,90;
